BlendedTomato
- Jul 25, 2013
Hello people, I am looking into building my first loop. It will be a cpu only loop and it will be in a 900D. The loop will cool my POS overclocker i5. Here is what I will put in my loop. I have done research on parts for MONTHS now but I would still like people to check if I have everything correct. I will be purchasing everything from performance-pcs. Here is parts list with reasons for getting the part.
CPU BLOCK : XSPC RAYSTORM (cheap and good performance)
RADIATOR : ALPHACOOL UT60 480mm (good performance)
PUMP : SWIFTECH MCP35X (PWM DDC and cheaper than PWM D5)
RESERVOIR : PRIMOCHILL CTR 240mm (apparently not prone to cracking due to compression ends)
TUBING : 10 FEET OF PRIMOCHILL ADVANCED LRT (apparently its DEHP free, aka plasticizer free)
FITTINGS : BITSPOWER G1/4 BLACK MATTE 1/2 ID BARBS (high quality)
CLAMPS : PRIMOCHILL BLACK HOSE CLAMPS (cheap)
FANS : YATE LOON D12SM-12 FANS (cheap and apparently has decent performance)
BIOCIDE : IANDH SILVER KILLCOIL (don't have to worry about putting in ptnuke everytime I flush)
I would like for the loop to have high quality parts. It also has to be silent. If you have any suggestions for parts, please tell me. I want to spend a maximum of ~400$. Also, I do not need a fan controller, I ripped out a power distribution board from an Antec P280. I will eventually toss in a GPU, either a HD 9970 or a GTX 880.
