- Jan 6, 2004
- USA
Very cool looking mod, and very original!!!
Hmmm that sounds interesting I'll have to see how that would look...it might not match with the circuits...but I'll try it, good idea.
safronz said:Did you know you have to be over 18 to buy super glue??? I sure didn't - I'm 17 and have a full time job yet I can't buy something to stick things together with?! Ugh
BTW, I love the southern accent I'm in Montgomery, AL at the moment Howdy
OK, that mod got you my instant respect.
Really, great job. I hope you win that San lan contest or something you're all talking about.
That case really deserves it.
Oh, and now you can solder, you can really make the fans lines go via the strips.
You may want to sand the upper layer a bit at first. I don't know about what material you're talking, but my guesses are that the surface isn't coarse enough for the flux to really grip on and it looks as if there is some polishing on it. It may insulate...
Mark620 said:LOL I got carded for buying Plastic fusion epoxy (in housewares its a 2 part epoxy) at Walmart, and I have been buying alcohol since I was 16 and never been carded (in 25 years). I was buying the epoxy to fix my daughters glases....
safronz said:Haha, did the glasses fix?
Sniperboy said:That is a very cool mod!! For version 2.0, you should think about using an actual method used to produce circuit boards. It's called the iron-on toner method. Take a look at http://www.fullnet.com/u/tomg/gooteepc.htm
You could use this method to make the toner stick to your case, then paint that section and wash away the toner. With this method, you can make .0125" thick lines with .02" spacing, which would be very cool! This would be very hard, but would look even cooler!
