Hello everyone,
I finally pulled the trigger on getting Ryzen 2700 non-x, x470 Taichi, and Flare X 3200 cl14 RAM. I got 2700 instead of 2700x reasoning that I could put $70 toward a custom loop which I could use with other processors or even GPUS (which get hotter than CPUs imho) on the future. What ever rout I will go in the future I think having a custom loop is cool and gives an owner more control over his/her hardware.
My budget is $120 for AIO +$70 I saved on the non-x CPU. I want to do soft tubing as it is less painful and cheaper.
I want to create a custom loop and save. Ideally I would want to By reading articles online, I found out that most people end up with more parts then they needed or that do not fit, so they resell them. The market for such parts is much more less liquid and they usually go on big discounts. Having no experience in building custom loops, what should I pay attention and stay away from when buying used parts on forums, like holes in the radiators, etc.
Thank you.
Thank you.
