I have posted around here before and sort information from here and there but last time around I wasn't quite ready so I didn't really tamper too much
well today I have proudly over clocked and changed some stuff which I hope you can give me a general heads up about anything that doesn't look right
Original PC specs
i7 920 @ 2.66 turbo like 2.9
Corsair CM3X2G1600C8 - 6 gig @ 1600 mhz 9-9-9-9-40?-81-1T (not 100 percent)
Asus rampage II extreme
Nvidia 295 evga
stat 1000 gig @ 7200rpm western digital or something
Antec 1200 Case
Got a extra bolt on CPU fan 80-120mm not sure I could check if it matters.
ok so here is where I tell you what I played with and did
firstly I tested a basic setting involving
Core Voltage - 1.30
QPI Voltage 1.40
CPU PLL Voltage - 1.88
DRAM Voltage 1.65
checked the ram at 1600mhz
this auto set FSB to 160
and off I went I had a little power showing @ 3.2 ghz and 3.4 in turbo
After a while I decided to play with my ram changing the timing to something like this 8-8-8-8-20-41-2T which from what I read won't be such a bad thing.
I couldn't figure out why I couldn't get my CPU ghz higher than a friend told me to touch the FSB so then I put FSB to 190 which auto set my ram @ like 1900
After my pc didn't start I managed to lower my default of 1600 mhz that auto clocked to 1900, I put it at 1333mhz which clocked @ 760 DRAM being 1520 mhz
the FSB being at 190, brought my cpu to 3.8 ghz and 4 ghz in turbo mode (21 x multiplier)
after Everest 30 minute stress test on everything.. it seemed to be stable (from what I was told I need a 30 min CPU RAM stress test to make sure its reliable/stable)
with temperature averaging 77-83 and upping to 85-87 in last 10 minutes
After seeing the max Core Voltage @ 1.38 I upped to 1.38 from 1.35 which a friend using 190 FSB was also @ 4 ghz 1.38 core voltage.
So now I would like some advice and anything that looks out of place or you could suggest, and when do I define this stable.
Lastly on top of that 6gig of ram I have another 6 gig my brother picked up from the states for me, the code checks pretty much exact model but a newer batch or update and just wondering what kind of settings I would need to touch to make it run, as previously I tried plug n play method with no luck
Everything was done in the Bios but here is the Asus tool to view in windows, DRAM Voltage is at 1.65 because at 1.66 in bios it says that it's not recommended to go higher or it can damage the CPU, it's strange because I have everything else turned up higher without any notice or warning, but in the picture below its well away from the middle let alone red line
Original PC specs
Nvidia 295 evga
Antec 1200 Case
Core Voltage - 1.30
QPI Voltage 1.40
DRAM Voltage 1.65
