First project in progress
Cooper58d
Ft bragg
Well I took some better pics hopefully this gives a little better res
The case is in the first stages of sanding to get the old finish off the standard finish does not hold paint very well
Got the idea for the turbine mod from the mod gallery it is my inspiration.
I'm cutting the holes for the fans with a jig saw and a wood cutting blade (not the best choice for bits it'll rattle your teeth off recommend metal bit I'm to cheap to go and get one)
I have been watching these forums for about a month now and have little bodywork or metal working experience. So if your a begginer like me look at the stickies and live by them they help out greatly
this is the back of the front of the case the hole is a 4" pvc pipe and the fan is 120mm
I know my garage is filthy but the filth keeps the wife out and prevents her from putting her stuff in there
the turbine fan mod is easy the tutorial is in the case mod gallery
Believe me I'm cheap. The whole thing so far has cost me $30 us. thats including everything the fan, bondo, pvc pipe, nose cone, and paint, (which includes crome, red, white, and blue, going for the patriotic look.)
:D I tell ya I haven't had this much fun on a project in a long time. I am defenitly hooked I'm already thinking about the next project and I'm not even finnished with this one. :attn:
wow, very nice mod so far, how did u get the bondo to make it look so curvy? did u apply it and then sand it down? anyways, can u tell me how to do the turbine thing and everything, i cant ook thru pages of case mods :D
The exhaust for the blowhole is going to be modeled after the exhaust from a helicopter. (It's only fitting because I worked on them.) :cool: and I plan on watercooling the Mobo,CPU, and GPU in the future. I need to get more knowlegable on it first been reading the stickies in the watercooling section. for now I'll just have about 7 million fans in the thing. :beer:
http://www.mnpctech.com/mal This is the link I used to get all the materials and tutorial from hope this helps coodoes to the man who did this mnpctech awesome:cool: :D
TCnet said:
I take it the Kiwi is for your boots and not the case? :p
Ya I thought about spit shining the case and then I remembered that I really don't shine my work boots that often. :rolleyes: So I thought it be prudent to not shine the case because of the whole hypocrosy thing:)
