- Mar 24, 2014
- Austria
Hi guys! Long time lurker, first time poster,
It has been a few months since I upgraded my CPU+Mobo and now I'm thinking about treating my CPU (and my ears) with a water cooling kit.
I have set my eyes on the XSPC RayStorm 750 EX240.
http://www.xs-pc.com/watercooling-kits/raystorm-750-ex240-watercooling-kit
Secondly, because my current case can't handle a 240mm rad, I'm thinking of switching to a NZXT Phantom 530
http://www.nzxt.com/product/detail/134-phantom-530.html
Sadly there is no easy cooling solution for my GPU (as it is a non reference design). The only one I found was a universal GPU water block that does not cover the VRMs - would this be viable with only passive VRM heat sinks?
So for now I will just do a CPU cooling loop, and when I feel like upgrading my GPU, I'll expand the loop with a 120 or 240 rad and a GPU water block.
As I am totally new at this, I would like to hear your opinions/advice on this.
Also, I couldn't find a comparison between the raystorm 240 and the raystorm 280 rad - any advice?
Thanks!
My Specs:
Mobo Asrock Z77 Extreme 4
CPU Intel i5 3570k OC @ 4.2 ghz
CPU cooler Thermaltake Contac 39
RAM Corsair Vengeance 2 x 4GB DDR3-1600 CL9 (OC to 1866)
GPU MSI R9 270 Gaming (GPU OC to 1110 Mhz)
PSU BE QUIET! 530 Watt 80Plus Bronze
CASE Silverstone PS06 (Positive Airflow 3x120mm 1x180mm)
Aftermarket CPU Cooler Thermaltake Contac 39
Thanks!
My Specs:
