Hey, I am planning on building a new computer this summer, and was thinking I'll ask for some help from you guys
What is your budget? 1300 €
Does this include a copy of Windows? Yes, I am buying one
Does this include peripheals (a keyboard, monitor, mouse, speakers, etc.)? No, everything else i got, also planing on using my old 1tb HDD.
Are you from the United States or a different country? Are you ordering from your own country or from across borders? I live in Finland and can order across borders.
Wherever you may be from, does the store that you are planning to order from have a website? It's okay if it isn't in English, we can manage. www.silentrig.com / www.jimms.fi/ both finish open to good eu sites tho!
Do you have any specific requests with the build? No
Do you plan on overclocking? If yes, do you have a specific goal in mind? Lite, 4,1 GHz
Would you prefer the build to be particularly small? No
Would you prefer the build to be particularly quiet? Preferably yes.
In general, do you prefer this to be a computer that you can spend money on now and let it rest, or a box built for continuous upgrading? Spend now.
Do you ever plan on utilizing NVIDIA's SLI or AMD's CrossfireX technologies? These features, with a compatible motherboard, allow a user to link multiple identical graphic cards together for added performance. In real world terms, this lets you buy a second identical graphics card down the line as a relatively cheap and easy way to gain a fairly large boost in performance. However, this requires buying a SLI/CFX compatible motherboard and PSU now, which may result in slightly higher initial cost. Not in the near future.
So these are the parts I'v chosen so far:
asus NVIDIA GeForce GTX 670 DirectCU II TOP
Intel Ivy Bridge i5-3570K,
AsRock Z77 Extreme4
G.Skill 8GB (2x4GB) Dual Kit Ripjaws DDR3-2133
Noctua NH-U9B SE2
Corsair Force Series GT 120GB, 2,5"
Fractal Design Define XL
Super Flower Golden King 500W
Windows 7 Home Premium 64bit SP1 FI OEM
Do you see anything wrong with the build ? Can I get better stuff for the same money ? Do i need the extra fan if I'm only planning on doing lite oc?
And the budjet is around 1300 €.
Thanks for your help in advance .
AsRock Z77 Extreme4
Noctua NH-U9B SE2
