After countless hours of research, these are the parts I have selected for my first ever Water cooling system:
MP-05 pro cpu water block
MAZE4 GPU water block
Danger Den Mag II Le pump
Black Ice Extreme II radiator
Masterkleer 7/16 ID tubing (10 FT)
12 hose clamps
4 oz zerex coolant
T-line
$195 (my budget is $200)
so what do you guys think? Is it a good system?
Is the Black Ice Xtreme II designed for high CFM or low? What low cfm radiators are in the same price range if the xtreme II is rated for high?
Also, I have found very little info on the pump, but it is all I can afford.
Other CPU block I considered were the apogee and white water. Should I get the Mp-05, apogee, or white water?
thank you in advance!!
12 hose clamps
4 oz zerex coolant
T-line
