First of all, my cpu is AMD Phenom II X6 1055t
I know I have liquid cooling but I have no clue what it is specifically.
This is my first try ever overclocking a cpu, I put it up to 3.5 ghz by watching a tutorial from youtube:
I started my PC back up and ran core temp just to see my general temperature and occt. I ran occt for only 10 minutes, 4 of those minutes being maxed out. I realize I should run it for probably an hour or so but I just want to test to make sure I didn't screw up already.. if you guys can tell from this basic information.
With that 4 minutes of maxing my CPU the temp maxed at 45C and my idle is 26-28C. As I type this it sits at 26C.
Does it SEEM like everything is running well? Core temp says my TjMax is 67C which I assume means that's the highest my cpu can safely go but that's just a guess.
Would I be safe as long as I personally monitor the temperature on my other monitor while I play games and such? Is there something else that could go wrong without me knowing other than the temperature?
