- Dec 21, 2009
Hello Ladies and Gents--this is my first "real" watercooling build. A while back a posted some issues with my pre-fab bigwater setup, and have since gone to air in the meantime and done some extensive research. The rig is in my sig--and the parts I'm going for are listed below, please comment and provide any suggestions!
Case: Mountain Mods Ascension (Triple 120.3 rads in the front)
CPU Waterblock: Swiftech GTZ
GPU Waterblocks: EK-FC470 (2)
Radiators: Triple 120.3 - Either the HWLabs Black Ice GTX Extreme, or the HWLabs SR1 (3)--from Skinnee's site, it seems that the Extreme is better for high fan speeds and the SR1 is better for Medium fans speeds, haven't decided yet if I wan't to put up with loud fans yet (advice?) I have a feeling I'm going to go with the SR1, however.
Pump: Laing D5 (Swiftech MCP655 w/ .5" tubing)
Tubing: Tygon R-3603
Fans: Panaflo or Yate Loon (need advice here, too)
I used the TDP calculator, and came up with about 250W ea for the vids, and went conservative with 275-300W on the CPU
I'd like to do this in a single loop (for simplicity) as follows
Reservoir (not decided on which one yet) -> Pump -> Rad 1 -> CPU -> Rad 2 -> Rad 3 -> GTX470 #1 -> GTX470#2 -> Reservoir
From looking at the Skinnee labs data, it seems that I should be easily able to attain a DT of 5C. Note that I realize this may be a bit of overkill, but I would rather be safe than sorry, and I want room to add an additional GTX470 in the future. I also plan on O/Cing both the CPU and the Vids.
I also need some help with some details of fittings (I really like the compression fittings). Also, is the Laing pump going to be able to handle 3 rads?
Many thanks guys!
PS This will be taking place over the next 2-3 months (have to "strategically" buy the parts when the wife is out of town!!!)
PSS I also saw Conumdrum's build with the (Koolance WBs) 2 x GTX470 pics, which I really like, and would love a parts list for the vid cards!!
Many thanks guys!
