- Sep 15, 2007
- Small town Emlenton, PA
m0r, ask the gold question over at XS, you'll get a better answer than I and other can give. I think it's a mountain. Never heard of gold causing problems.
I get annoyed with the Yate Loon High's (D12SH-12's), Mediums or Lows are much more pleasant on the ear, just food for thought. Looks like you did your research and have asked plenty of good questions, nice work!
Also, 275-300w is high for the CPU. Realistically, 200w is plenty, but the high side estimate will just mean lower water temps, which is always a good thing.
edit: Mort, everything is G1/4 now unless the description says G3/8... to my knowledge only a couple products out there by Bitspower that use G3/8.
OKay, I'll ask.
I went with the D12SH-12 from your review on the SR1--it seemed to be the best performance compromise between the low speed and really high speed YLs--especially given that the SR1s are better for the lower speed fans (as opposed to the GTX Extreme 360). I also don't want screaming fans, but I think the mid-speed (from your review, believe the D12SH-12 is 1800 RPM?) should be workable.
I figured the 275-300W figure would be high, but in my inexperience, I decided to go on the safe side for now.
Thanks for the compliment, and your site is great!
I don't know of any books...but there is our sticky, the sticky at XS, and skinneelabs.com, between all those you might as well have a book
Ohh mokr, you seen this one in all the threads you read? I have posted it as a lazy catch all. Was for one guy, but it has lots of goodies outside here. and al in one spot.
http://www.overclockers.com/forums/showpost.php?p=6489396&postcount=3
