- Jun 10, 2014
- Finland
Hello.
I have finally got the chance to build a new PC. You guys don't even know how long i've waited for this!
Im just wanting to check that my WC components are OK!
Im probobly going to expand the loop by cooling my GPU aswell in the future.
Here is some info:
- CPU: i7 4770K 3,5Ghz
- OC goal: Im probobly aiming for like 4,5Ghz OC
- Room temp: Mostly room temp is about 20 - 22C
- Case: Going to buy the Corsair Obsidian 750D
WC Components:
- Koolance CPU-380I
- Alphacool NexXxoS UT60 360
- Laing D5 pump (Koolance PMP-450S)
- Photon 270 Reservoir
- PrimoFlex Advanced LRT Tubing 7/16 ID
- EK Compression Fittings
- Noiseblocker NB-eLoop B12-P Fans
- Cooling paste: Arctic Cooling Arctic MX-4
That's about it!
Any suggestions?
Thanks.
Here is some info:
WC Components:
- Koolance CPU-380I
That's about it!
Any suggestions?
Thanks.
