Hi
My new Rig:
CPU: Intel i7 5930
GPU 2x EVGA GTX 980
MB: Asus Rog extreme x99
RAM: Corsair Dominator 2666 DDR4
PSU: Seasonic 1000W
HDD: 500Gb Samsung evo pro SSD, 2x 3TB WD black
CASE: Corsair 900D
Water cooling parts:
- 2x 480 black ice SR2/GTX rads ( still didn't decided)
- D5 pump don't matter what brand.
- Rigid tubing clear still didn't decided from witch company.
- CPU: EK-Supremacy EVO CPU Water Block (Original CSQ) - Nickel/Acetal
- GPU: 2x EK-FC980 GTX Waterblock for Nvidia 980 GTX - Nickel/Plexi
- Fans: Corsair SP120 or AF120 quite edition (still searching)
- Tube res 170m/200m EK or primochill still looking.
- Fittings and connectors??? (rigid compression fittings of course)
- Coolant: distilled water+Mayhem pastel blue.
Water cooling: 2 Gpus + CPU
I am planning my water cooling for the first time, so i decided to go with rigid tubing, i know its not easy for first timers but i am welling to learn and do it the best i can, all i see is 1/4 sizes ID 3/8, OD 1/2 what i don't understand is if i wanted to add connectors or splitters, some times like the pump there is only 1 size for it, so i have to add for example 1/2 to 1/4 like that, so how i can determine how many connector i will be needing? the fittings are fine i will choose bit power or monson but as i saw the bit power has more options and rotary in fittings and connectors, so perhaps i will go with bit power.
So now, the fittings i know how many i will get by deciding for how many holes i will be using, but the connectors for example from the pump and split to 2 rads or 3 this is what i am worrying about, a lot of sizes i have to measure, how i can make it easier for my self because i am kind of confused
My new Rig:
CPU: Intel i7 5930
GPU 2x EVGA GTX 980
PSU: Seasonic 1000W
CASE: Corsair 900D
