- Nov 12, 2002
- Rootstown, OH
AngryAlpaca, you are wrong on part of that - ONE DOES NOT WANT A LOW FLOW RATE THROUGH THE RADIATOR. Don't take this personally, this is just a common falsehood that A LOT of people still claim as true.
The graphs derived from Bill Adams radiator dissipation testing clearly show that most models of radiators perform considerably better with higher flowrates.
Higher flow rate makes the radiator dissipate more heat, this is shown in the graphs below. Dissipateing more heat is better. Water doesn't have to sit in the rad in order to cool down, it just has to continually move through the radiator so heat is constantly taken out as fast as possible.
Water sitting in the rad means the waters temperature differential between the air is less which leads to slower heat transfer. Sitting water is bad.
The graphs can be seen here. Higher flowrate is a lot better for some radiators, and a little better for others. Slower flow is almost NEVER better:
http://www.thermal-management-testing.com/corrected heat dissipation.htm
You can also look at some of my explanations that are more thorough in the 30-40 posts before this one.
