My mistake about swiftech.com. It's actually Swiftech @ swiftnets.com.
Yeah, I'd agree with you that manufacturer's findings are suspect, but that test was done at this site: http://forums.procooling.com/vbb/sh...rpage=25&highlight=pump and test&pagenumber=1
There was a good number (subjective ) of people in on that test: Phaestus, BillA, and others.
I see the error that you made note of on swiftech's website. Vewy stwange!
But I disagree with you on the second statement. All waterblocks benefit from higher flow. Thermal-management-testing.com and overclockers.com websites show how the waterblocks perform under a controlled environment. I'm not going to go into their testing procedures because it has no pictures.
But here's the website: http://thermal-management-testing.com/methodology.htm
I made no such assumptions about water temps.
All results show that more flow = better waterblock performance, up to a certain point, where the graph flattens out and any increase in flow results in a miniscule increase in performance. That's where the decision on pump performance versus price comes in.
Yes, in a home system, where temps would vary from the test temps, results would sway in either direction. But, if a side by side test were done under the same conditions, higher flow would work better than lower flow.
Off the subject, if flow is a problem, such as with a white water waterblock, where backpressure is high, then I'd go with a bigger radiator that is free flowing in both air flow and coolant flow. That'll help the pump keep what flow rate it can make and the bigger size will allow for more surface contact. Luckily (well designed, actually) the white water block works very well with low flow. I've noticed a lot of people going to that block, recently.
