QuietIce
Disabled
- May 7, 2006
- Anywhere but there
I think all my boards have the heatpipes and I've never had a heat problem like that either. Obviously a well-stressed IGP does put out some heat, something I never run into since I've only got a couple of boards with built-in graphics and they're SETI farm rigs, so they never see heavy graphics use.
Edit:
Cross-post ...
I'd arrange the side fans as one IN, one OUT unless you've got a big open grill somewhere - but that's just me ...
Edit:
Cross-post ...
I have replaced the TIM on the heatpipes on several of my rigs, even removed the thermal pad on the MOSFETs without problems and replaced it with Ceramique - but mine weren't very uneven (a little bit uneven though). The first rig I did that to has been running since Nov '06.NeurOmancer...As I stated earlier, I installed two 120mm fans in the side panel blowing directly at the NB and the temp dropped from 60C down to 51C. That is when I began to suspect that even though hwmonitor listed that temp as cpu temp, the NB temp was what it was actually reading. Speedfan had that high temp listed as the NB...and due to the low core temps of low 20's, confirmed by several utilities, I figured that the cpu temp couldn't be that high and that it must be the NB.
There is always the very real possibility that there is just a faulty sensor which is just reading too high, in which case I would just turn off the high temp warning in Bios...but not until I am certain of that.
After I took off the NB/Mosfet heatpipe, the gunk that was used for TM looked awful... chewing gum consistency...and about as hard to get off.
I appreciate your input. This is certainly a learning experience for me.
I have some Arctic Cooling MX-2 and I think that I will go ahead and put the cooler back on and just see what happens....process of elimination...see how well the new TM works.
