- Oct 11, 2002
- The Empire State
Help guyz! My dang res froze up again. This is 3x already and this time it almost killed my cpu.
I have an external WC setup i built and i have it on my windowsill.
I'm using a mix of:
75% distilled water
10% water wetter
15% anti-freeze.
Apparently, this mix is not working cuz my res keeps freezing up. After un-freezing my lines, rad and res, i decided to go with a closed loop and eliminate the res. I'm still using the same mix of liquid, my cpu may have already been damaged cuz now it needs more voltage to run @ the same speed. I cleaned off the AS3 and reappplied it.
I was told to either go with methanol ( where i have no idea where to get it at) or isopropyl alcohol. I'd rather go with the alcohol since it was told to me that is has better thermal properties than the crap mix i'm using now. My rad holds a little over 2 quarts of liquid.
1) How much of the alcohol do i need and
2) do i mix it with distilled water ?
Any help is greatly appreciated!
I'm using a mix of:
75% distilled water
10% water wetter
15% anti-freeze.
