- Nov 12, 2002
- Rootstown, OH
I need input for getting a higher FSB on this board. Using a FX-8120 currently, same issue on FX-6100.
I can't raise FSB higher than 263MHz without immediately crashing, what should I try in order to hit 270FSB, 280FSB, or 290FSB?
In testing, these were my settings. Let me know if you have any suggestions or questions...
CPU Multi: 17X
Vcore: 1.85V (LN2)
CPU-NB Volts: 1.55V
CPU-NB Multi: 9X or 10X
HT Link Multi: 9X or 10X
Ram Voltage: 1.8V (11-11-11-40 2T)
So at 263MHz FSB for example, I'd be 2630MHz on CPU-NB and HTLink, and 4471MHz on CPU frequency. I've tried memory dividers of 1066 and 1333 - my RAM is rated for 1600MHz, so at 1066 I would only be hitting 1400MHz on the RAM, and at 1333 I would only be hitting 1750MHz.
The CPU can do 31.5 X 257MHz, so core frequency and temps aren't holding me back - I just can't figure out why I have this FSB limitation. Any ideas?
CPU Multi: 17X
Vcore: 1.85V (LN2)
CPU-NB Volts: 1.55V
