- Apr 17, 2004
How many rads can you fit inside the FT03?!
Set out to have a cool, quiet system, without having to put any radiators outside the case. Current setup can't run SLI, but can adapt the cooling slightly and move the radiator out to fit another card if needed.
Just finished my build, here are some specs and pics:
Hardware:
FT03B
Asus Rampage IV Gene
Intel 4930K
Gskill 32gb RipJaws Z PC2133
Corsair AX860
EVGA 780 GTX TI SC
Samsung EVO 250GB
Hitachi 3TB 7200rpm
Cooling:
Swiftech Apogee Drive II (Disconnected as it is too loud, may eventually change this out for different block)
XSPC Raystorm GPU Block
MCP35x Pump (Primary Pump)
Alphacool ST30 280mm (Cougar 140mm fans)
Alphacool UT60 120mm (2x GT AP-15 fans)
Alphacool ST30 240mm (2x Slim Phoyba fans)
XSPC EX120mm (Slim Phyoba Fan)
EK and XSPC compression fittings
Overclock and temps:
CPU: 4.6ghz stable at 1.38v (temps idle around 30c, 75c max load)
GPU: Have not overclocked over the factory standard, temps are 27c idle, 47c max load
System is dead silent at idle with all fans and pump controlled by motherboard. Loudest component is the Hitachi hard drive under normal basic use
All case cutting for radiator and Lexan window was done by Jason at waterjetnj.com in NJ. He did an amazing job making sure everything lined up perfectly and was very clean. If anyone wants the window or any FT03 case cutting, he has my drawing saved, so it will be very easy.
Appreciate any comments / thoughts!
Not the best pics, but just took some for now with my phone:
Hardware:
FT03B
Intel 4930K
Corsair AX860
EVGA 780 GTX TI SC
Samsung EVO 250GB
Hitachi 3TB 7200rpm
Cooling:
