- Jan 7, 2013
Anyone Overclocked an AMD FX-4100. If so, whats your build and what settings did you find most stable?
No, but from my understanding of how CPU Level Up works, it automatically adjust vcore as well.....sorry, I didn't bother to recall voltage as I was just messing with it, had already made arrangement to sell it with the CVF + FX8120 on the way.Did you mess with the voltages at all to push it past 4.3?
Nah, the CVF was a used board, while the FX8120 was brand new......this was a ways before Vishera hit the scene btw. No regrets, it's a decent CPU and, if you'd note my avatar, I'm one huge ROG fanboy. This FX8120 + Asus CVF + 2x GTX670 SLi'ed is my 2nd rig....should I need more raw processing powah, I can always use my main rig - 3960X + Asus R4E + TriFire HD7970 for sheer POWAH!@ "GamerDude". Did you get the FX-8120 in a 'deal'? Maybe in a classifieds buy? There is nothing wrong with a CHV non-Z mobo for sure, I have and like mine with the FX-8350 I have now after replacing my FX-8120. In the things I do with 'my' computer the FX-8350 does more work even at the same speeds I ran the FX-8120.
Highest stable I've had mine with a P95 run is in my sig, cooled on air. Other than that, I haven't gone any higher because I've hit the temp barrier. Still, I'm pretty happy with mine at 4.2 for daily use, I can even push it up to 4.6 easily with good temps and reletively low voltage, but after that I need to start pumping to volts to it.
Anyone ran some benchmarks and see what speed gets the best performance. I have seen a lot of of people say that after 4.4ghz it starts becoming counter productive
