Damn that's why I keep overpaying when I send packages .A semi truck scale is probably not going to be accurate in weighing a first class mail envelope but will be when you put a truck on it.
I use Angus Monitor to show both temperatures. >> that is a good monitoring program but most of us are too cheap and use freeware stuff. The author of the program explains pretty accurately the way that AMD temps are actually read and then displayed.
The CPU socket temperature is about 10-12C higher than the core temperature for my FX-8350. >> With your Corsair H60 Cooler, that is about what you should see. The delta from socket temp to core temp is about what it should be.
I have found that HWMonitor's "TMPIN2" and EasyTune6's "CPU" to also be the CPU socket temperature.
HWmonitor says it's running @ 16C!!! Are my eyes deceiving me??
