- Sep 12, 2013
My setup was a stock FX 8120 with mobo 78mlt-s2 and 2x4GB G.skill 1333mhz DDR3 ram. I was running at 3.5ghz OC with stock fan with no freezing or problems except that the CPU temp would hit 61 degrees when testing full load with prime95 blend test. While gaming it would touch 55 degrees max. So i went for the ETS-T40 to cool it down and maybe even OC a bit more like 4ghz. So i got it in (which was somewhat a pain given i didn't know how gigantic this thing was lol I had to remove both of my side panel fans of my raidmax mid tower...) and boot up with stock cpu BIOS settings. Boots up with no problems, temps were below 30 degrees which was awesome. I do a prime blend for a couple of mins, maybe 5 mins, and it didnt even get to 50 degrees. So i went ahead and got it to 4ghz since its so damn cool now (setting all conflicting features off like c1e, cool&quiet, core boost, etc). Boot and right after login in it reboots so my guess was i needed more Vcore voltage but since i wanted to test temps at my old 3.5ghz OC with stock heatsink/fan I went and set it to 3.5ghz with lowest voltage setting which was completely stable before. It NEVER EVER froze or restarted with the damn stock fan. I test prime again... Froze while running test... I lowered to 3.3ghz... Froze again... So then im thinking maybe i put too much thermal paste. Removed the heatsink and there was a little bit dripping out but nothing major, the stock thermal was dripping a heck of a lot more and never froze... So I am pretty sure it wasn't that but I went ahead and cleaned and re-sit. I also re-sit my memory stick just to see if one of them wasn't making good contact since i worked around that area. Reboot... Now prime runs without issues at 3.5ghz but im still getting random freezing!!! Now it froze twice while shuting down. I'm thinking on setting BIOS oc back to stock and see if I get any freezing as I haven't tested that. But I would appreciate any input if anyone could tell me a specific common cause of this issue. I though it was shortcirctuiting but its not temperatures because the temps are always below 50 degrees even with OC. My next step was going to run memtest86 on the memory modules to see if one of them went bad. Everything is less than a month old.
Just to define freeze: My Windows screen gets stuck, nothing moves and my HDD LED doesn't do anything. Its just stuck on whatever screen it was at. I was considering giving it like 10 mins to see if its moves again but since theres no HDD activitiy I didn't consider doing that.
P.S. Just a side note: When i was taking the stock heatsink off, the CPU came off with it... But since i always pull my heatsinks straight up, it didn't bend any pins thanks to God. Bent pins wouldn't even boot my thing right? Just incase the freezing could be a bent pin but i highly doubt it.
