Hey guys new guy here .. nice to meet you all
I got the idea to overclock my amd fx 8120 processor and I need your wisdom and knowledge because i'm not completely noob but i'm not exactly confident in my overclocking skills.
I tried to do it safely via AMD Overclock utility.
I open it, i press "autoclock" and then start
it finished at these settings:
Current CPU clock is: 3900 MHz
Current HT Link ref. clock is: 200 MHz
Current CPU multiplier is: 19.50 X
AutoClock is finished successfully!
I pressed "apply settings" aaaaaaand nothing happens.
i thought i might need to restart for the new settings to be actually applied but even after restarting the cpu was still stuck at 3.1GHz.
Am i doing something wrong?
I know it's better to oc from the BIOS but there are tons of things that could cause big disasters in there and as i said i'm not very confident in my oc-ing skills so .. i didn't want to mess with anything in there until i was sure about what i am doing.
So the main question is:
1) why it doesn't work?
and
2) can i copy the settings from AMD OverDrive and configure the BIOS settings according to these values/settings?
Oh and one last question.. my memories' default voltage is 1.65 Volt according to patriot, but when i run cpu-z or everest they say their voltage is 1.50 Volt. Should that worry me?
My system is this:
Asrock 990Fx Fatal1ty (UEFI v1.6)
AMD FX 8120
16GB RAM (AMD Performance Edition 1600MHz)
Gigabyte HD6850-OC
750Watt power supply
Thanks.
and
My system is this:
AMD FX 8120
Gigabyte HD6850-OC
Thanks.
