- May 20, 2012
I oc'd my processor to 4.0 ghz on 1.29 volts and it booted up fine ran prime 95 and two of the workers had stopped straight away. so i knew the problem i upped the volts to 1.335 volts ran prime 95 again no problems this time. I have read in multiple places that i should be able to get the 4.0 ghz clock on 1.29 volts stable but it seems to me that i cant get it to run "Right" on that voltage.
The only thing i have disabled in the bios is the Performance boost
My Specs:
FX-8120
990FXA-UD3
Corsair TX750
Coolermaster hyper 212 evo
Corsair 500R
7800 GT (Temp gpu)
E: another issue im having is the right program to use to check temps HWmonitor says my proc is 44c and AMD overdrive says its 54c which is more accurate?
My Specs:
FX-8120
990FXA-UD3
Corsair TX750
Corsair 500R
7800 GT (Temp gpu)
