Well,
I've put the 8120-FX stock HSF on my 955BE (with a Hyper TX3 fan), and it runs 3.7 GHz/1.375v/55°C max.
Amazed: it does the same job the Hyper was doing!
Well, your Hyper TX3 must not have been doing a very good job then...Well,
Stock FX coolers are the same as stock Phenom II Black Edition coolers are the same as stock Athlon 64 FX coolers are the same as stock Athlon 64 X2 6000+ up coolers.
Nope, I got a terrible "one block aluminium" cooler with my PhII x4. And a copper base/heatpipes one with the FX.
Wow that is really interesting.Nope, I got a terrible "one block aluminium" cooler with my PhII x4. And a copper base/heatpipes one with the FX.
Mine came with this one:
I modded it somehow (using the alu base and fins) with epoxy to make a custom WB on my first loop.
Can not find any pic of it any more...
I made a "casing" around the the base (with 5mm remaining fins) with epoxy, with two 3cm long/12mm diameter tubes on the top for inlet/outlet.
It was tighten to the cpu with metal wire.
It was actually working ok, but I kept it for no more than two weeks before getting a "real" block. Kind of afraid it leaks some time...
Running mixed metals is a no-noI modded it somehow (using the alu base and fins) with epoxy to make a custom WB on my first loop.
Saw a review of the new FX-6200, they come with a new larger heatpipe cooler that comes with an 80mm fan.
The AMD forum has been modifying the Phenom II heatpipe coolers with 80mm and 92mm fans for a long time. I have glued 80mm to 120mm adapters to these coolers (I know, but..) and used Arctic 120mm PWM fans. An improvement and quieter when stressed.
The larger cooler would be super easy to mod.
The TX3 is a better than stock cooler, but not by a lot. The Loki is rated better. for a 92mm fan cooler.
I have gotten the solid aluminum coolers with some Athlon II purchases. Not very effective if stressed. I had heard some Phenom IIs were shipping with these (solid aluminum coolers). Bad choice AMD.
