AMD Turbo Core Technology: AMD Turbo Core Technology and Application Power Management (APM) allow
the CPU cores to run above the CPU Base clock value as long as the CPU remains within the thermal and
power limits. As an example the AMD FX-8150 CPU has a base clock of 3600MHz but it can run at 3900MHz
when up to 8 cores are active and at 4200MHz when up to 4 cores are active assuming it stays within the power
and thermal limits. Under very heavy workloads the CPU will return to the base clock – 3600MHz in the case of
AMD FX-8150 CPU.
Since APM sets a predefined TDP limit it is usually recommended to disable both AMD Turbo Core Technology
and APM features when increasing the CPU frequency and voltage above the default levels. The AMD Turbo
Core Technology and APM can be disabled via AMD OverDrive utility or from the motherboard BIOS menu.
