empirebeige
- Jul 12, 2013
I am trying to overclock my FX 8150 CPU, and I've checked out several written guides and videos on how to do it. I've gone with the easiest method, ie. gradually increasing the multiplier and the CPU voltage if needed. My problem is that even with a modest level of overclocking I have to crank up the voltage significantly. At 4200 MHz I am already at 1.475 volts, and the system is still not stable. The default speed is 3600 MHz, and the default voltage is 1.25.
On forums and in the overclocking guides for this CPU I've seen people get up to 4500 MHz with less than 1.3 volts. One guide claimed that most Bulldozers are able to put out 700 or so extra MHz with the stock voltage alone. So I'm a little confused. I don't want to go past 1.475 V because I've read that with air cooling it is the safe maximum, and indeed it appears that at that voltage, on 100% load, my CPU temps are hitting the high 50s. I have tried overclocking through the BIOS and with AMD Overdrive (Win 8). Both methods yielded similar results.
I've thought of two possible limiting factors: My motherboard is a budget micro ATX model (Gigabyte GA-78LMT-USB3). However, the BIOS has all the necessary options for overclocking. Also, I have 16 gigs of Kingston DDR3 1333MHz CL9 DIMM non ECC memory, which is another budget-conscious choice. Could these be the problem? I'm using a Zalman CNPS7X LED CPU cooler, and a Corsair 600W 80 plus bronze PSU. My graphics card is a Sapphire Radeon HD 7870.
I'm not planning on breaking any records here. Reaching 4,5 GHz would be ideal, but I'd be happy with less if I can make it run pretty.
