CPU overheating I NEED HELP
Hello,
I saved up for a very long time and finally build my gaming rig:
GA-990FXA-UD3 mobo
asus gtx 570
amd fx-8150
hyper 212 heatsink
8 gig ram
coolmax zx-700w psu
corsair r300 case
After building the computer getting drivers and bios set up it worked like a charm. I played for a good 5 hours bf3 and then started to experiment with overclocking the gpu but couldn't get it to run stable; bf3 kept crashing after a couple minutes.. So I reset the gpu and wanted to play another match but after 2 minutes my pc just shut down. Tried it with gw2 and was monitoring my temperatures and sure enough pc shut off after 1 minute..
Problem: CPU gets hot and pc powers down after it hits 62C.
Every time I start a game the cpu temp starts to skyrocket.
I have a freakin vortex in my case so I can't make sense of it! 4x140mm intake 2x 140mm outtake 1x 120mm outtake.
I'm about to go get some rubbing alcohol so I can clean the heatsink and cpu and reaply the thermal paste and see if that helps.
But the heatsink sits rocksolid and there was no problem when I first fired the rig up.. I mean I played for like 5 hours straight without any problems!
I'm really worried and burnt all my hard saved cash on this system and now I'm just starting to freak out.
I've read this forum for a long time and know that you guys are a smart bunch! I really need your help!
Sincerely,
Dan
Hello,
GA-990FXA-UD3 mobo
asus gtx 570
amd fx-8150
hyper 212 heatsink
8 gig ram
coolmax zx-700w psu
corsair r300 case
Sincerely,
Dan
