- Oct 9, 2012
- Earth!!!
I have overclocked to 4.1ghz and the core temperatures are between 50 and 51 however the cpu temperature says 63. Which one do i look at?
Both. Try to keep socket under 70c and core under 62(at least that is what amd tech support said to me)
EDit 60C not 62 EDIT END
Why cant customer support just give a straight answer???
At 4.1Ghz? Then freeken awesome man if that is what you get running P95 Blend mode. If that was during P95 then you should be very very well off under normal circumstances.
I have some benches on my FX-8120 that might better answer that about CPU/NB. The stock as designed by AMD is 2600Mhz for the CPU/NB. Running that fast can raise heat but you should not notice it until you push a good deal beyond 4.1Ghz. Fast ram might be helped some by raising to 2600Mhz but my benches don't show much gain in 'real' performance. Again I say that you should do okay moving to 2600Mhz but when I pushed way up into the 4.8Ghz range, the increased CPU/NB raised temps pretty heftily.
By the way make us a signature so we know what you got inside the box.
My how to put up Sig at OCF.
New Shortcut method for putting a Signature with your system information following your every post so people can know what is in the case that they are trying to assist with. You can use something like what is shown in my signature as a good template of needed information Thank you.
I'm running my A10-5800K at 3.1V to the NB.
e-mail no: 2
Dear Tiberiu,
Your service request : SR #{ticketno:[8200510844]} has been reviewed and updated.
Response and Service Request History:
Core Temperature would be the case. Socket temperature is more motherboard
specifications. You'll have to contact the manufacturer of the motherboard. Normally
you should see within the BIOS the CPU core temperature is the idling temperature.
You should be able to configure the motherboard to automatically shutdown the
computer or give warning should it go to 60oC.
I recognize that circumstances might prevent you from being able to respond in time
with the information that I have requested. If I do not hear back from you, the
service request will be permanently closed after 10 days. If more time is needed,
please reply back to me before the 10 days expire.
In order to update this service request, please respond, leaving the service request
reference intact.
Best regards,
AMD Global Customer Care
__________________________________________
