Anonaru: you mean let CPU PLL auto and twice bump cpu vcore? or set CPU PLL at 2.515 and then twice bump vcore?
Trents Im uploading it right now, sorry didnt know,
So okey now here it is. What should I do next?
So okey. I set ram to 9 9 9 27 and DRAM voltage to 1.65
Now IM trying to bump twice the vcore and How am I supposed to know if my ram memory is okey?
The lock up you're getting isn't typically associated with RAM. I think your RAM is fine, but thought I'd give it a run. Upon a little more research (And Ajay lending a hand, thanks ) it seems like there may be a hardware issue--
There's quite a number of people who are having difficulty overclocking the 8150 on that motherboard. It very well could be something we are powerless to work around
Well you mean bad mobo? How bad it is ?
I did something, bumped twice vcore Dram set to 1.65 and 9 9 9 27 ram memory timing multiplier at 21 4200 mhz and well I DONT KNOW WHAT I HAVE DONE BUT IT WORKS||||
5 minutes without freeze lets hope it will be okey
Core temp 33 celsium cpu temp 56 celsium
Nooooo. After 11 minutes freeze whyyy. What now?
But I still cant get why it was working now for longer then before and only with Twice bump v core ...
As I mentioned before I am perfectly stable at 4.1 without increasing a thing...but the 4200 is issue. Re-running now
Totally same result. In same time after 11 minutes of test mouse freezes
Okey set up as you said. Windows loaded, I will edit when I will know more
Edit1: running some test I think I even decreased the vcore its now 1.28
Could we later get some online chat where we can speak faster? I mean after your work
4 minutes of test core temp 32 and cpu temp 55.
It makes a noise I m not sure if its CPU or Pump in h100i or even fans
EDIT2:
the noise is like vrm vrm vrm vrm (increasing and then slowing speed of fan I suppose) or I dont know.
Stable for 14 minutes now.
temps core 32 still and cpu temp 57
EDIT3: Well after 14 minutes the sound disapear and mouse freezes right after the sound disapearing ..
Well i didnt lower Vcore I just set single bump instead of 2 bumps of Vcore
Everything as you said. Vcore only one bump but
Well I will try the second bump but I guess it wont work out. Well one month ago new bios was released and its 1604 which I have, so I will wait a loooong time i guess ( Its really issue in mobo and cpu? How other users of this mobo OC? How much Im so unlucky
