Hey Anonaru i am back sorry for being away so long, so tell me Bro you can not open the posts???? Let me know and i will try to explain to you both!! AJ.
That meants?
Using an overclocking approach that combines raising the multiplier with raising the Front Side Bus (aka, "CPU frequency" and "HT Reference") does often allow you to user lower voltage for a given level of overclock. I strongly suspect the 6+2 power phase (as opposed to 8+2 or better) is the culprit here. Really, the only motherboard that Asus boards that are not giving problems when trying to significantly overclock the eight core FX chips are the Sabertooth and the Crosshair which are the flagship Asus overclocking products.
It also can help if you position a spot fan or two to blow air directly on the VRM/socket area of the board.
I will prolly try to aim some fan onto the socket area
umm. i found that the 1604 bios is really bad for the fx8150. i had throttling issues on an m5a99x with 1604. when i downgraded they all went away.
I tried everything from the start, increasing more HTT to 210 and multiplier only to 20 to achieve 4200 mhz still loaded succesfully and then few minutes of test mouse frozen and fans just went from 60% to 10% all the time same issue. Dont know what I can try more. What is it caused by? Low vcore or wtf?
