It behaves alot like the phenom IIs but with a few differences. The FX chips can handle voltage swings very well. Disable all the turbo stuff, and the big one is to make sure you disable Application Power Management or you will get unexplainable throttling. Im pushing 4.2ghz 24/7 @ 1.28v with LLC it pushes up to 1.33v. On air or water consider 1.37 to be your limit for 24/7 and 1.4v for benching IF your cooler can actually keep up with the FX's heat production.
