- Jan 10, 2012
johan45 is back in, he's the man with the plan, perhaps he will be kind enough to chime back in.
Sure thing C_D, so Ruby what's the goal? Are you looking to speed thing up or still trying to cool things down. I checked out that case and want to know if those 80mm fans are intake or exhaust?
I wondered about that case, it almost looks like it would exhaust the cool air before it gets to the CPU where it's needed. Is it possible to turn those around?? Typical airflow should go like this
So I can't help but think that those two fans exhausting so close to the intake are a bit counter productive.
yes and manualy setting them is the only way to go, further down the line you will find out why.
on the heat thing, everything that makes a computer work harder or raises a voltage makes more heat.
the trick with these very hot running processors is to get up against our heat wall (up to max temps) then balance the system with cpu/nb and ram. we get the biggest bang from the processor so we get it up to speed first, then cpu/nb and ram, we give up ram and cpu/nb first and cpu speed only as a last resort.
Thanks a bunch, how did you find out that the optimized bank cycle time was 33 ?
Bank Cycle aKa tRC is shown in the SPD menu for CPUz. So not too hard to find. All that calculating for optimized stuff is not for you if you did not know where to input the 5 major timings. So the ram maker says 33 for tRC. Other calculating is not necessary for looking at optimized tRC.
RGone...
Stuff is not for me that sounds a little bit insulting to me sure i am not a know it all but that doesn't mean that I don't want to learn it.
Thanks anyway
Maybe he should have said at this point. RGone wasn't trying to be insulting or demeaning. Memory work takes a lot of time and patience and can really muss up a BIOS to the point that the computer will not post. Give it some time and if you're really interested there are people here with some really good minds that don't mind helping out.
Good, I'm glad. Just that we would really like to avoid buggering things up before you get to have some fun with that thing. If the BIOS gets scrambled it can require an RMA and then you'd be without a system. None of us want that. Me , I'm willing to take those chances but I also have back up parts if something goes amok.I wasn't looking for apologies here it's just that you need to see every person as equal with the ability to grow in knowledge without judging.
And don't get me wrong here i do admire his and your knowledge it really helped me alot.
