- Apr 13, 2012
- South East Ohio
- Thread Starter
- #21
right now, run the blend test, it also tests memory.
small fft just makes heat for you right now, so get what you can get with blend, then worry about the others later, it's time for you to learn also.
please open enough copies of cpu-z and show us all the tabs.
cpu-z is kind of cool, you can open all the copies you want.
what version of prime95 are you using?
I'm using ver 26.6 build 3. I asked because I just installed this CPU in my system that had a FX6300 stable at 4.4 GHZ. I didn't make any other changes except voltage and multiplier changes to get this CPU to overclock. I didn't think my memory would need tested since everything was stable before. I've heard different amounts of time to run the test to determine a stable overclock. I've used 2 hours in the past but have heard anything from 20 minutes to an hour to 3 hours. Do you still want to see all tabs?
Thanks
