- Jan 19, 2014
- holland
hello guys i have a fx 8350 pared with a asus r9 390x will the cpu hold back the card ?
quastion 2
im running my cpu at 4.387ghz with a voltage during load of 1.408v lower its not stable it turns out i have a crappy cpu, 4.5 will do at 1.452v under load and 4.6ghz will not even run at 1.525v
running now with a fsb of 225 it will set the nb freq at 2475 and the ht also.
i set my cpu-nb voltage to 1.225v and all the rest at auto, can i do somting more?
the mother bord is a msi 970 gaming
and after setting the settings in the bios, i forgott to change the memory diverder, i left it at 1866mhz, stock, s its set it self at 2150 but with cas 13, while stock is c10, will the higher speed even if its not much give me more perfomence, then 1800c9
quastion 2
