Scotty did you look on the side of the unit? It says 25A on the 12 V and also 237w max output power directly below it. Um what? I will also add the 3.3v and 5V rail says 150w when the 3.3 V rail is 21A and the 5V is 15.Yeah....25a ain't gonna cut it. 40a minimum IMO.
Ow man... bad thing that I don't have much money to buy all those things... uh...
Can you afford to replace the whole setup if the Psu goes and takes the whole thing with it? We have seen it happen.Ow man... bad thing that I don't have much money to buy all those things... uh...
W_HEQ, not sure how that early chipset motherboard will actually work to try and DISable cores. To get to that menu in bios which is set up for Phenom processors you have to turn on ACC which is no longer supported with later cpus or is an antiquated AMD process. ACC was dropped from most AMD bioses by at least the 8xx chipset if I remember correct. Sort of gave me the 'shakes' when I looked at his manual and bios to see if you could even turn off a core.
RGone...
