- Aug 14, 2014
What would be max voltage i can use for CPU/NB on my 8370 ? 1.2v isn't stable, 1.25v runs sluggish, 1.3v seems fine but 1.35v is what hits the spot speed/fluid wise if that makes sense (everything loads/runs faster), but at the same time have to consider the LLC slight overvolting. Asking because some reviews say 1.3v max and others say 1.4v max on air cooling. Also on HWInfo64 i seem to see every voltage but CPU/NB...
4.7ghz 1.431v multi 23.5x
HTLink : 2600mhz
CPU/NB : 2600mhz
CPU LLC : Ultra High
CPU/NB LLC : High
RAM : 2x8gb 1866mhz 9-10-9-27
Sabertooth 990fx R2.0
HTLink : 2600mhz
CPU/NB : 2600mhz
CPU/NB LLC : High
