- Aug 14, 2014
So I finally got around to troubleshoot the memory issue I've been having with my 8370, it simply does not like RAM above 1600mhz. Good example of this would be my CVPro 1866 c9 only run stable @stock if I bump CPU/NB to ~1.35v and memory to ~1.55v. I have another set of 1600mhz c9 that runs fine @stock (I have been running the 1866 at 1600 7-8-8-24 24/7, Chrome seems to love it).
So I decided to switch to my FX-4300 to see if it had the same issue with the memory and it runs perfectly fine 5ghz 1.428v - CPU/NB 1.3v - 1866 c9 1.5v stock no issues. Then i tried bumping speed to 2133 9-11-11-31 and 2400 10-12-12-31, again no issues with a very slight bump to CPU volts. Is there any tips to try to improve my 8370 or is he "doomed" to stay at 1600 ? Specs are in my sig
