Rarely, if at all.it could run 2400mhz kit.
Vcore on all FX's winds up around 1.5v +/- when you get up around 5 gig. I can even give you a comparison cause I have em all.The 8320 was rotten yeah. but the 9590 was about the same just lower vcore
It might be rotten by now yeah. The 8320 was rotten yeah. but the 9590 was about the same just lower vcore, it could run 2400mhz kit.
All of those FX chips from the starting 4100 to the 9590 are not voltage or memory limited by any means. First having the right motherboard would make a huge difference talking about a daily overclock and capability. The memory SPEED wasn't as crucial as how you would set up the timings for X clocks. So then back to the Processor overclock for the best gains. Fighting for higher speeds while you loosen the memory timings. I was running 1100mhz with 933 sticks at 9-10-9-27-36 2T while getting better results at 800Mhz - 900Mhz and looking for at least Cas 7 clocks.
ANd FX processor is not Voltage limited either. It's the cooling. You could run an FX chip all day on single stage closer to 6Ghz and then your memory speed just won't matter. The draw back was Ill returns after 5.8Ghz, the difference in the benching with 200Mhz gain didn't really boost scores or reduce times significantly.
On geothermal water loop, my greatest Top clock cpu-z validation was at 5.7ghz. Did lots of testing with various cooling solutions including Peltier or TEC coolers Dice and LN2. Colder = Faster, Use voltage appropriate 1.65v is good on Dice up to 6Ghz. LN2 then becomes Rotten or Lucky pick of the draw. I haven't hit 8ghz myself, but then most of the time I was using a board that just wasn't capable of doing the task.
Concentrate on Cooling and Cpu speed more so then the memory.
And for help with higher memory clocks, try raising the CPU/NB voltage.
What amazes me the most is how high those chips can go! Seeing 5ghz+ clocks on fx doesn't seem like rare deer in the woods. Intel, not so much. Sad part is, Intel gets a lot more done per clock. Wasn't it the opposite in the earlier and days where less clock didn't mean less score?
Yes, very true, but OTOH, cpu might overclock higher to make up for the lost difference ?
wut?But it OCs like an Intel....
And then it keeps BSODing
Boo
Its more than just tweaking multis to make an overclock stable
Intense voltaging and stressing
I did discover that the motherboard's built in "overclock" (4600 MHz all cores) way overvolted. I did try working it up the normal way, too. The voltage takes some tuning either way if you want all the energy saving goodies back on. Besides the audio, the biggest plus I got this board for was the voltage pads. I can throw an Extech VOM on it and get my real numbers. That lets me "overvolt" according to the software, but it's still well under max for the chip and RAM. Accurate vdroop readings that way, too.
