- Dec 16, 2015
hello guys new to the forums here. for the longest time i have had issues with my 9590 it would lock up all the time with default bios settings and the only way to get around it was to disable turbo core and the 5ghz claim to fame is one of the reasons anyone even bothers with the damn thing in the first place. quick specs of my set up below
fx9590
asus sabertooth rev2
crucial balistix 1866mhz(16gb)
g1 gaming 980ti
735wpsu
custom water loop 240mm rad
so i have finally made a break through and gained some stability as well as dropped load temps down from 53-55c all the way down to 45-47c in cinebench
the solution? i added a 90mm fan fastened with a rubber band and 2 screws to the vcore heat sink on the mother board. so with this simple addition i am currently siting at 5ghz on all 8 cores (turbo disabled) WITH no additional voltage
i never would have thought this would have helped considering my case has lots of fans and great airflow. and i was starting to lose hope, but this works for me
i hope this helps if anyone else is having similer issues.
fx9590
g1 gaming 980ti
735wpsu
