Maybe or sort of...
Thermal Design Power (TDP) @
http://www.cpu-world.com/Glossary/T/Thermal_Design_Power_(TDP).html
The Thermal Design Power (TDP) is the average maximum power a processor can dissipate while running commercially available software. TDP is primarily used as a guideline for manufacturers of thermal solutions (heatsinks/fans, etc) which tells them how much heat their solution should dissipate. TDP is not the maximum power the CPU may generate - there may be periods of time when the CPU dissipates more power than designed, in which case either the CPU temperature will rise closer to the maximum, or special CPU circuitry will activate and add idle cycles or reduce CPU frequency with the intent of reducing the amount of generated power.
TDP is usually 20% - 30% lower than the CPU maximum power dissipation.
Average Maximum ?? I thought Max was Max. How can one average a max? Every cpu would have to be tested in order to get average of a Max. Probably some sort of word playing.
So TDP is n0t a theoretical max power. Nor by those definitions is TDP the worst case scenario.
Both AMD and Intel have sort of played a little loose and free with how they define TDP. Get the white papers out and you can read for yourselves.
Now for power consumption pointers; AMD is trying to use ACP (Average CPU Power) which none of the big guys use. Instead, the big industry players like Intel, Sun, HP and IBM have settled on the suite of SPECpower benchmarks run by a committee of industry players hailing from all those firms and even AMD. This, for the most part, promotes TDP (Thermal Design Power), a measurement Intel favours and which AMD considers inherently biased.
If you have not spent nearly 2.5 years with the 8 core FX processors thru Bulldozer and Piledriver and run them on something less than DICE, LN2 or LHE, then it is hard to really have experienced the power the 8 core processors (actually all FX cpus) can consume and throw off the resultant heat at higher constant frequencies. 4.8Ghz and beyond is a load on the cooling system and motherboard VRMs.
In truth, I doubt many people benching for points that are not in the top 10 around the world, give a hoot what AMD says about power consumed or heat generated anymore. At least not in the discrete cpu market place. Gamers are interested in IPC and that falls to Intel to lead currently. AMD has stated time and then time again that they have no interest in competing in the upper tier of discrete cpu performance. They completely stamped this as TRUE when they did not bring a "steamroller" variation to us discrete cpu users.
AMD gave us "consumers" nearly 11.5 months of HYPE before releasing the Bulldozer onto the consumer. When they sent the first Bulldozer Review packs out to the review sites they had probably the best mobo packed with the cpu (CHV with correct bios) and the AMD water cooler and a special review package for monitoring from CPUID.
By this manner of bet hedging, the average consumer had no idea what they would face when they turned ALL the cores on and began to overclock as most of us do with BIG WATER on a "hefty" VRM circuited mother board. The review sites wanting to continue to receive test parts and pieces; fell right into step and only said the FX cpus did not bench equal to Intel at relative speeds. Again a gap in real information to the amd buyers.
Not the first bit of this has any real meaning to 98% of the computer buying market. There are only a small segment of users that hinge their next drawn breath on the performance of their computer in benches and how far can they overclock their cpu. Just a small segment of the computer market place.
Now AMD execs are leaking more hypeage about something for x86 again in 2016. Hold your breath.
Just an FYI. I have a good FX-8350 used for home video editting. It literally lifts the front end and totes the mail down the track for me in that usage. I like it. But I do not appreciate the hypeage that makes most of us that do the helping in the AMD cpu forum section 95% of the time; feel like mobo police from users coming in wanting to overclock with entry level mobos that are not up to the task of ALL cpu cores turned on while overclocking, which is necessary if you want an FX to finish just behind an Intel cpu clocked at a lesser speed.
Long live those whom can put up with the stress of "mobo policing".
RGone...ster.
