You did what?
You might be correct in the difference being digital VRM vs analog VRM, "ssjwizard".
I also hear clearly "MediaJunky" when he says 0.0125 is not enough lowering of voltage to justify using a raised voltage that the full results of so so doing have not been determined. Crap we are not even sure what the raised VDDA is is actually changing on AMD that seems to bring good results in some cases.
I mean my gawd the how to overclock a processor is nearly anywhere on the internet that you want to look and this AMD forum section is FULL of how to overclock and yet we get post after post wanting to know how to overclock somebodies processor. Can you imagine trying to help some newb that already has more information available than one can begin to imagine and try to coach that type of user thru the use of VDDA?
I linked "Johan45's" use of VDDA to help get a 'presentable' overclock of an FX-8350 on an ASUS M5A99FX PRO R2.0 motherboard. His was a very special situation it seems and he was far and away from the type that posts "how do I overclock my X". He spent hours tweaking VDDA on his own without posting anything and came back after he had results. What he got was a low enough Vcore to be pleasing to him but ONLY about 50 more Cpu Mhz increase but the increase had him dead in the middle of 4500Mhz cpu speed and he was happy since he "seems" to have one of the newer Vishera's that just don't want to overclock like one expects after the BullDozer cpus.
I mean really the only reason I re-opened the efforts for testing VDDA myself some more is because the 'idea' is being thrown around with little real results being spoken about here in the AMD Cpu section except for mostly 'ssjwizard', 'Anonaru' and myself I guess to begin with. All three of us and "Johan45" have been testing raised VDDA on both generations of FX cpus and now also "MediaJunky".
"Johan45" has the ASUS M5A99FX PRO R2.0 which is a 6+2 DIGI+ VRM motherboard so in reflection "ssjwizard" I may not agree with VDDA not working so well on my CHV since it is using Digi+ VRM. "ssjwizard" I only realized what I just wrote after attemping to bring together in one place what we 'think' we know. Funny way to speak I know. Not sure I know anything.
I only want to put as much real information into one location as we can so that those that actually TEST can do so. I begin to surmise we might be able to generally say:
1. NO clear answer as to why raised VDDA has helped anyone lower the Vcore on some FX type processors has been determined.
2. Long-term effects of raising VDDA has most certainly NOT been determined.
3. Increased CPU_PLL aka VDDA seems currently more likely to work on some Gigabyte analog VRM circuit motherboards.
4. The Maximum VDDA has not been determined anymore than #3 above.
5. Increasing VDDA to try and lower temps and Vcore IS NOW and will always require user performed trial and error testing to determine if there are any results to be obtained from raising VDDA.
Do those five points seem fairly accurate to date?
I will say now that before I got up this morning and saw MediaJunky ask if anyone had tried lowering VDDA, that it had crossed my mind to try such. I previously tested my FX-8350 with NO more than 2.52-ish VDDA and when I started to test last night I jumped right up to 2.64 VDDA and got poor results. Upped VDDA again and even poorer results. I am now in the 2.55V VDDA voltage range and my results seem more promising. I think if I find any good result it will be with less than 2.6V VDDA and my temps and Vcore will only be lessened by an amount similar to what "MediaJunky" is reporting in his post just above. In other words not nearly the seemed good results that some Analog VRM circuit Gigabyte motherboards appear to have as a result of raised VDDA.
I am of the mind right now that if one wants to try to raise VDDA to see what happens, there is no need to ask about it but rather to do it and test it out for themselves and only then after complete testing...report what the result is. We have no idea overall who maybe helped and certainly not how much the help will be nor how much VDDA to add to get a positive result. Newbs likely need not attempt this at home.
Maybe we are current to date now. Off to test some more. RGone...ster.
