- Apr 20, 2004
- JAX, Mississauna
Speedfan?!?
EDIT: I apologize. I just learned it has been designed by a NASA thermodynamics engineer!
That makes him privvy to AMD NDA information and his code above reproach?
Speedfan?!?
I am stuffing the pig into a haf x 942.
the top 200mm fan plus the one i added were restricting the airflow out of the top grills.
all the lights on this box are red, a color i don't see so, i have to look at the front mounted pump/res with the blue led to know if it's on.
Oh, I see. It was in Prime95 you changed the affinity, not in CoreTemp. Yes, I see that now as I look more carefully at the picture. Sorry.
But it would seem this only has a bearing in our interpretation of temps when cores are either locked or unlocked. Cores cannot be unlocked with the FX CPUs and I'm not sure there are any to unlock even in the 4 and 6 core FXs so the sensor will always be in the same place with regard to the core positions on a given FX line. I suppose that may not be true if you're moving between the 4 core, 6 core and 8 core lines. What do you see as the significance of this discovery?
That's exactly right.
What this means is that basically both TCase and TCore don't really reflect the actual temperature of the CPU.
In the case of Intel's TCore, you have a sensor in every core, thus you can see the temperature of each core independently and be sure that your CPU is running within the range of temperature that you want it to run in.
In the case of AMD it seems that it's really impossible and we can only depend on some average values calculated using some formula.
I'm really baffled as to why AMD decided to go this route... They had proper sensors in each core in the K8 days. They sometimes weren't calibrated really well, but at least we had a reading per core.
Intel does it, VIA even does it (which Core Temp supports for TCore as well ) but AMD doesn't, and it's just confusing.
I have a P-II X6 1090T here as well. I'll do some testing on it as well, just out of interest.
It'll also be interesting to see if other FX users can replicate my results, and also what the results would be on FX-4000 and FX-6000 series of chips.
My point was that in the current situation we have no way of knowing what is the hottest spot on the CPU, like we can on Intel and VIA chips.
With AMD we can only get an average temperature, which doesn't necessarily reflect potentially critical temperature being reached by the processor.
I guess that if AMD engineers thought that this is a good way to go, there is probably a good reason for it.
I can only assume that Intel follows a similar path when it has to report 'external' temperature, like TCase, which puts us in the same spot, but for us enthusiasts, we still have TCore temps to rely on if we so choose.
Probably why they made the "maximum operating temperature (Tcase Max)" a "conservative" limit. IMHO it doesn't really matter which temps you decide to use, just as long as everyone understands that when they see the "maximum" temp listed on the various sites and product descriptions by AMD that it's not referring to "core temps" otherwise they'll run the risk of running it much higher than the stated max temp.
Yeah, that makes sense to me and it's actually what we've been recommending around here for some time without knowing all the technical reasons why, speaking for myself. This has been a very rigorous discussion and though I wasn't able to follow it at all points I think it fair to say it has been very helpful to me to bring some clarity to these mysteries.
