So I decided to try and oc this cpu some. Right now i have a bootable usable oc but fails stresstest after about 20min with possible hardware failure message. P95 and Overdrive give this message
4.5GHZ effective
FSB 250
Multi 18
ram at 1336 "i have 1333"
Both nb and ht link set 1780
vcore 1.35
I have a multitude of the digi-power control settings altered and forgive me for not knowing which but most are set one notch above normal.
temps are ok. package gets to around 42C and socket 50C.
I'm on water as you can guess, and I have 4 70mm cpu fans set up in a square around the cpu. two to the left on the vrm heatsink and two to the right over the ram and some downdraft to the chipset but its hidden behind my gpu.
Now I know i have some tweaking to do. HT and NB need to go higher and I could probably back down on the FSB and raise my multi. But what's getting me is this seams like my oc is way high for such a low vcore. Is it throttling down and i not know it?
I know its not a cut n paste deal when overclocking. But what are some of your results with this CPU.
System specs in sig
4.5GHZ effective
FSB 250
Multi 18
vcore 1.35
System specs in sig
