Woomack, I really beg to differ.
To increase performance, you overclock. And you increase performance more (even if a little bit as your saying) if you OC the entire system.
Umm wall?? Since when? FX stock is HT 2600mhz effective clock. The NB should EASILY run 2600mhz. Try increasing chipset voltage WITH the CPU/NB voltage, then you should be able to run 3ghz on the NB no problem.
Somehow it was never looking like that when I was testing AMD FX. HT can go even up to 4000MHz but it's not affecting performance so barely anyone is setting it much higher than stock ( or equal to CPU-NB ). CPU-NB on most chips won't run much above 2600MHz. 2600-2800MHz are the most popular clocks for longer tests. Good samples will make 3000+ but at higher voltages and usually good cooling. 3000+ CPU-NB was easily running on Phenoms, not so much on FX.
CPU-NB clock is what affects memory/memory controller performance but it's not overclocking high so performance gain is also not so much visible.
SO much to say in return to this one statement.
FX is fun to OC period. You do not need LN2. Basically it's more challenging. And if you don't like a challenge, then ya you get the OC only overclock with cpu performance gain only... But why??
Frustrating because of lack of research. How many times through the years have guys like you and I gone through the saying "you should have asked first" just as I did while inquiring about the best board to use for LN2 and a 9590 to try and join the 8ghz club. BTW I'm only 800mhz shy of this on a M5AMX L plus or w/e the part number was basically a POS board for LN2 but was able to pump nearly 1.2v with it and a 4+1 power phase. This time, trying to do it right instead of cheap.
It's fun but not for long. If you get FX CPU from higher series then it won't overclock much higher without high voltages and good cooling. Most users have no access to LN2 so they OC 300-400MHz and nothing more. It's frustrating for many users who are buying this platform reading various comments and later ask for help on the forums like our AMD section. You probably see how many threads are there with various issues about AMD FX/APU and overclocking due to motherboard or overheating issues. So yes, it's fun as long as you have best motherboard and you actually know what are you doing.
I've learned not to buy cheaper 990FX board in the hard way. Burned 2x 990FX-UD5 and 3rd had dead BIOS. After 3rd RMA I just sold it but before that I also made couple of guides for Gigabyte forums how to solve RAID issues and some other things. I didn't want to risk another bad board so I paid some more and I got CHV which was actually one of the best boards I had. At the beginning were issues with BIOS and RAID was slow but some users made BIOS with MSI ROM which solved everything.
So why I sold AMD ?
- it was too hot for my daily rig and too slow for benching, I also have no good LN2 access to test it at high clocks
- I hit a wall on memory clock and bandwidth, it didn't like some new memory sticks so I had to make tests only on Intel - AMD was collecting dust
- is bad for memory comparison, simply every higher clocked kits have to be downclocked to keep stability and then most of them perform almost the same because of IMC limits
- I got a good deal for CPU+mobo when it was still worth something ( Polish market of used hardware is really hard )
Know how comes with practice. RGone may call this wisdom as every piece of HW is different.
But if your interested in OCing a i7 to 5 ghz and beyond.... you'll find the same problem being frustrated with cooling. I know because my 3770K was hot as hell at 1.5125v and 5ghz. daily? ya sure. stable? stable enough?
But really for some one in need of seeing a frame rate higher than the visible eye can read the number.... then yes you buy into Intel. There is no doubt. Intel is superior. But heck man, some games run better on NV cards and some run better on AMD cards (VGA).
So I suppose people should try all walks of life if to make this a hobby.
The main difference is that with lower MHz gain you get higher performance gain on Intel. You don't really need 5GHz for a daily rig when everything is working fine on ~4GHz. On AMD FX I had to overclock CPU only to play couple of more demanding games without visible lag and I really saw the difference overclocking these CPUs. For me it's just not right that you have to overclock "high performance" CPU only to play not even new games.
To have any descent performance on FX8120/8320 I had to run them @4.2GHz+. At the beginning it was giving me about the same performance as i7 950/Xeon X5550 @3.8GHz which was generating less heat. Some time later I back to AMD and I got APU A8 6600K. To make it perform good I had to set it to 4.5GHz. This was quite good chip which was running 24/7 @4.7GHz ~1.38V so not much above stock. Still I could easily replace it with i3
[email protected] keeping about the same performance in everything I was using.
Most FX users can't really run these CPUs at 5GHz. In most cases they stuck at about 4.2-4.5GHz. Every new unlocked Intel can make 4.5GHz stable without need of any special cooling.
I also can't get why so many Intel users need 4.5GHz+ for their daily rig ... to browse web, watch movies, play games ( not really so much demanding as most base on gfx power nowadays ) ...
Haswells are getting hot after OC but to perform as good as AMD you don't have to set anything above stock voltage and can use even simple motherboards.
I agree that overclockers should test all platforms, not only stick to one side and spread comments that other brand ( which they don't have and never tested ) is worse etc. Afterall it's all about playing with various settings and benchmarking. What's the fun to test over and over the same stuff.
btw. in Poland barely anyone loves American muscle because of fuel prices where 80% is tax
Recently fuel prices on international market dropped by about 50%, in Poland we see about 10% drop and government already thinks to add one more tax.
