- Nov 26, 2005
- Concord, NC
I was thinking your load temps were a little high for that HS. I'm getting better temps than that w/ the stock cooler on my 8800GTS-512. Good work!
Here are my results from stock speeds n stock cooler vs OC and HR-03 GT.
Stock (650c / 1625s / 972m): Idle-47 Load-69
3DMark06 12258
2.0 = 5631
3.0 = 5682
CPU = 2794
OC (760c / 1900s / 1062m): Idle-40 Load-59
3DMark06 12815
2.0 = 5797
3.0 = 6229
CPU = 2792
Does this look right? Or is my suspicion of my CPU holding it back correct?
Also the temps look a little high...
That is quite a nice OC for a GT, what is the XFX AD edition?
Did you do a volt mod or something?
Nevermind, you have a GTS, too early for me
Reboot-
The 3Dm05 CF test is really just for the vRAM. You still need to run ATI Tool for a while to make sure your core/shaders are stable.
Yes, the checkerboard thing you saw was the memory avalanche Viper was talking about.
As to why you lost 200 points...it could be a number of factors. Did you reboot between runs? There is also some amount of fudge-factor that has to be accounted for. Try running it a few more times, and see what happens. You could also try reducing the vRAM freq a notch or two, and see what happens to your scores.
thats about what I'm getting on mine with the same cooler,
I did just have lotro lock up on me, at 800x 2000 / 1099
after completing several 3dm05 passes with out any trouble...
oh well back to the lower speeds I cant mess with this stuff for more then a few hours at a time or i start to go nutty.
damn dude, how did you get an 8800GT up to 900MHz?! which mfg/model is that?900 / 2430 / 1053 (2106)
nice one!
You do not want to repeat all of the 3DM05 tests. Just Canyon Flight repeated 8-10 times for a GST's memory.
Viper
