- May 8, 2012
- Argentina
On my current overclock, the crappy NB HS gets VERY hot (touch or otherwise). As you can see in the picture, is on 63c after running Prime95 on Blend for over an hour.
I know that temp is not terrible, but that's hotter then what my GPU gets while gaming (GPU with a custom fan profile is around 59), is ridiculous. Even though I removed the useless pink paste that came with the board on the NB HS and replaced it with MX-2. (Before doing that it was like 10-15 degrees higher)
What I'm really curious about is if I can undervolt the NB, but I don't know what are the normal ranges for it. ¿Any one has any numbers to share?
Thanks in advance.
Thanks in advance.
