- Jul 19, 2012
- Brew City
Hello All,
I have a Gigabyte GA-H67M-D2-B3 (rev. 1.0) LGA1155 mobo with an Intel Pentium G620 dual-core CPU installed (F7 BIOS). I'm using a 120GB OCZ Vertex 2 SSD as my main OS drive. Win7 64-bit is installed and running fine. I have a couple of old 1st gen. SATA hard drives I want to also use with this system. Both are old-school Maxtor 160GB drives (will only use for storage). When I have them plugged in, the system boots up fine and recognizes the drives and assigns drive letters accordingly. After a certain time, the HDD busy light goes solid and the system becomes unresponsive. It doesn't matter which old Maxtor drive I have plugged in, this happens with one or both plugged in. I can unplug them with the PC on and the system operates as normal again. And with just my SSD plugged in, this doesn't happen at all. Could this be an issue with drive indexing within Win7 for the old drives or having the SATA interface configured as AHCI? I'm using the SATA 3 GB/s ports for everything. Any feedback/suggestions on what I could do to fix this would be much appreciated. Thanks in advance.
Other details: 8GB DDR3 GSkill memory installed; using onboard Intel HD graphics
