- Sep 5, 2001
Hi All
Surelly it should be the n-th post about this argument and it surelly could be a bit boring but I could not find the information I am asking for anywhere.
I changed my nice A7V8X mb to get this nice one: an A7N8X rev 2.0.
Like I have seen somewhere my rev. board does not need the VDD mod. in manner to be stable @ 200mhz...infact it is so.
Now I am running my cpu pretty stable @ 2400 mhz(200*12) using 1.675 voltage and all my games and bench seems to work without problems.
However the matter is that if I switch on my system initially it doesn t boot...it boots only after being entered in the bios using the safe mode and after saved my setting as well and restarted it.
At a first look could it be a voltage issue?
Maybe I am not so clear...so I repeat myself saying that currently my system is running at 200*12 and all seem to be ok but in manner to achieve this frequency I started my system in the safe mode(100*11.5) and then restarted it after saved all the settings just as I wanted.
Oblivious my memories are pc3200 rated.
So I whant to ask you if there is anything possible to "by-pass" this little startup issue.
Thanks.
Thanks.
