I found something usefull from nForcersHQ just using your link hangten...
Here they are some bugs that still exist:
***Bugs that co-exist on the new Rev 2.xx boards, will be highlighted in RED***
1.Memory speed reported wrong in POST (-1 MHz) *FIXED with 1004 BIOS* Reported by Karas*
2.Cold boot issue (BIOS not using its setting for CPU voltage on initial system startup when using some older/slower T-Breds (1700+ & some 1800+CPU's))
3. BIOS curruption on save *Mryaz reports this problem is very much alive, even on his new v2 with 1005FINAL BIOS!!!*
4.Weak AGP drive output at higher FSB's (GFX glitches/lock-ups/drop to desktop and system re-boots in 3D apps & games)
5.Insufficient chipset voltage *PCB modification method only at this time. *Can help with items 7, and 4*
6.Diagnostic voice reporting errors that do not exist *Does this still happen?*
7.Support for 200/400MHz Barton CPU *PART FIXED* This seems to help some, but not all with 200MHz FSB support*
8.Board insatbility when using ASYNC memory settings + & -
9.CMOS battery issues *FIXED* Just Replace CMOS Battery, Can help with Fault #3, but not in all cases.
10.Some gaps in the selectable FSB settings *Part-FIXED with 1004 BIOS. 201MHz is not available, others are not verified at this time*
11.IRQ setting for onboard MIDI being ignored *FIXED in BIOS 1004 (Reported by HellHorse)*
12.BIOS IRQ table not trying to avoid conficts at all (Only an issue if you have a device which will not work with IRQ sharing)
13.BIOS not properly reading SPD's on latest official Intel/JEDEC DDR 400 memory modules (Confirmed by OCZ, Crucial and Corsair)
14.CPU temperature reported incorrectly * koSmiQ reports that the BIOS cannot report below -0c*
15.Case/Chassis temperature reported incorrectly (Quite often higher than the CPU temperature! Or are often much lower than the real temps)
16.Q-FAN only works properly on high RPM fans +5,000RPM (Fan slows, but does not speed back up on sub 4,000RPM fans)
17.Motherboard resource issue with USB keyboard *FIXED with 1003 BIOS*
18.Crackling sound via Soundstorm/APU *Submitted by Spank* *nVidia have stated that new audio drivers will fix this issue, however new nForce drivers are some time away*
19.Data curruption when using built-in Sillicon Image SATA Controller *This is claimed to be fixed with BIOS 1005 for v2.xx motherboards. AWAITING CONFIRMATION*
20.Keyboard wake up from S3 state inoperative (but does from poweroff) *Submitted by Philwett* *Reported as FIXED in 1003 BIOS*
21.Wake up from S3 state NOT working when dual channel is used *Submitted by Philwett*
22.Standby (S3/STR) problems *Submitted by Jhong* *Thread Link
http://www.nforcershq.com/forum/viewtopic.php?t=14905&highlight=standby
23.Spread Spectrum will not always disable when user selects 100/133/166/200MHz FSB's. Can cause instability in some systems if enabled.
The 2nd one is very interesting
